[GRASS-user] ps.map: Area Fill Color Transparency
Fri Feb 26 14:53:54 EST 2010
Rich Shepard wrote:
>    Using the vareas section of ps.map, is it possible to specify transparency
> in the fcolor specification?
"fcolor none" should result in the areas be unfilled.
If you want "translucency", PostScript doesn't support that. However,
you can use the "pat" option to specify a pattern. Varying the pwidth
option should affect the effective opacity of the fill.
