[GRASS-user] ps.map: Area Fill Color Transparency
Rich Shepard
rshepard at appl-ecosys.com
Fri Feb 26 15:03:54 EST 2010
On Fri, 26 Feb 2010, Glynn Clements wrote:
> "fcolor none" should result in the areas be unfilled.
It does.
> If you want "translucency", PostScript doesn't support that.
Oh, that's right. Slipped my mind.
> However, you can use the "pat" option to specify a pattern. Varying the
> pwidth option should affect the effective opacity of the fill.
I will figure that one out.
Thanks, Glynn,
Rich
