[GRASS-user] Calculating Length Between Points On Stream Network
Jarek Jasiewicz jarekj at amu.edu.pl
Sun Feb 28 02:10:49 EST 2010
Rich Shepard pisze:
>   I have a vector map of a stream network and want to find the distance
> between two points on the main stem. I have the geographic coordinates of
> each point on the line representing the stream. I tried v.what but I'm
> not
> comfortable that gave me the correct answer.
>   The line between the two points is multiple segments where there are
> confluences with feeder streams.
>   What module, used with the GUI or on the command line, will allow me to
> calculate the distance along the stream between two identified points?
> Rich
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
try to use r.stream.pos but it work only with raster map
J.
