[GRASS-user] Calculating Length Between Points On Stream Network
    Rich Shepard
    rshepard at appl-ecosys.com
    Sat Feb 27 19:09:44 EST 2010
On Sat, 27 Feb 2010, Rich Shepard wrote:
> 242856.60 431305.07 242551.88 432149.70
   Oops! I forgot the 'id' at the beginning of the line.
   So, after adding that I get a new warning:
WARNING: Wrong input format: id 242856.60 431305.07 242551.88 432149.70
WARNING: [1] input format errors
   The man page says:
Nodes can be piped into the program from file or from stdin. The syntax is
as follows:
id start_point_category end_point_category
or
id start_point_x start_point_y end_point_x end_point_y
Points specified by category must be exactly on network nodes, while, when
specifying coordinates, the next node to a given coordinate pair is used.
   What I tried was to put the upstream easting upstream northing downstream
easting downstream northing as the points.
   What should the syntax be?
Rich
