[GRASS-user] Labels On Maps
Micha Silver
micha at arava.co.il
Fri Jan 1 06:18:24 EST 2010
On 01/01/2010 02:50, Hamish wrote:
> Rich wrote:
>> d.vect map=proj_pts type=point color=red
>> icon=basic/triangle size=10
>> attrcol=str_1 lcolor=red bgcolor=white lsize=12
>> I don't see the text in column 'str_1' on the display.
> add display=attr
Along this line, may I make a feature request/suggestion?
In the wxpython gui, when I setup the display options for a vector
feature, the choice of which column to use for the labels is on one tab,
but the display=shape,attr,cat etc is on another tab. Even tho' I know
this, I've found myself often selecting the the attribute column, and
forgetting to enable display of attributes, then wondering why the
labels don't display.
Is it possible to auto-magically enable display=attr once an attribute
column is selected for labeling?
Thanks,
Micha
> display Display
> options: shape,cat,topo,dir,attr,zcoor
> default: shape
> (yeah, d.vect has an abundance of options.
> if overwhelmed see svn/grass-addons/display/d.shortcuts/ )
>> Do I need to explicitly declare a font and the other
>> attributes?
> nope
>> If so, where do I find a list of acceptable names?
> d.font -l
>> Also, on a related note, how can I change the column
>> names in those .dbf tables?
> v.db.renamecol, or define them with columns= when running
> v.in.ascii etc.
> Hamish
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
> This mail was received via Mail-SeCure System.
