[GRASS-user] Trouble setting location and projection
    bharath1234
    bharath.settur at gmail.com
    Tue Jan 12 05:35:16 EST 2010
g.proj or projection error while loading shared libraries :libproj.so.0
cannot open sharedobject file:no such file or directories.
after click ok.... error in start up script:cannot read "proj_is_ll"no such
variable exists
while executing
"if { $proj_is_ll } {
# Explore mode is off by default (can't peer past 90deg)
set exploremode($mon) 0
} else {
# Explore mode is on by..."
(procedure "MapCanvas::create" line 38)
invoked from within
"MapCanvas::create"
(procedure "Gm::startmon" line 11)
invoked from within
"Gm::startmon"
(procedure "Gm::create" line 79)
invoked from within
"Gm::create"
(procedure "main" line 30)
invoked from within
"main $argc $argv"
(file "/usr/local/grass-6.4.0RC5/etc/gm/gm.tcl" line 566)
libraries :libproj.so.0 cannot open sharedobject file:no such file or
directories.
how to solve please help me?????????????????????/
View this message in context: http://n2.nabble.com/Trouble-setting-location-and-projection-tp4089392p4290798.html
Sent from the Grass - Users mailing list archive at Nabble.com.
