[GRASS-user] r.patch: GRASS-6.5svn -- UPDATE
Fri Jan 15 18:17:48 EST 2010
Rich Shepard wrote:
> >  There was a warning about inability to write line 24nnn (I forget the
> > exact line number), and when it was finished and I tried to display the
> > whole new map, only the top portion (I'd estimate the top half) was present.
>    I need ideas on how to find the source of the problem.
>    Made 3 horizontal maps, north, central, south from the 9 maps. No problems
> making or displaying them. However, ...
>    When I tried to patch the three together the error displayed 'unable to
> write row 24580.' I removed that map attempt and tried to patch the north
> and central maps together; this produced the error, 'unable to write row
> 24581.'
>    What might cause such an error? This is in the central band which displays
> without comment by itself.
The most likely reasons are:
1. Your version of GRASS was built without LFS (large file support),
and the cell/fcell file reached the 2GiB limit.
2. The disk is full or you exceeded your quota.
If you're building GRASS yourself, be sure to use the
--enable-largefile option when running configure.
