[GRASS-user] GLOBCOVER import and manage
Gilbert Ferrara
gilbertferrara1974 at gmail.com
Mon Jan 18 06:03:18 EST 2010
Hello Achim.
Thanks for your answer.
So what you are saying is that I cannot add a raster with a different
coordinate system to my location? So, every time I have a dataset with a
different coordinate system/projection I have to create a temporary location
and only then I can add right?
This is complicated approach because I have a lot of data in different
coordinate system that I need to integrate so for each one I will have to
create a project and only then import to my location. Right?
Uofff :)
By the way, If my IKONOS data has a smaller coverage than my Defined region,
what will happen to my IKONOS image? will it be stretch to cover all defined
region or it will remain with the same coverage, number of cols/rows and
pixel resolution?
Thanks fot your help
Best regards Gilbert
On Fri, Jan 15, 2010 at 7:45 PM, Achim Kisseler <ak7 at jupiter.uni-freiburg.de
> wrote:
> Hi,
> What you are trying to do is a "on-the-fly projection". GRASS does not do
> this, because that doesn't work properly (as I understand, but I don't know
> why).
> What you have to do is to make another location with the different
> coordinate system and import your data there.
> Then go to your location, you want to work with. Here you can use the tool
> v.proj or r.proj to import your vector or raster data.
> Have a look at:
> http://www.grass.itc.it/grass64/manuals/html64_user/v.proj.html
> or
> http://www.grass.itc.it/grass64/manuals/html64_user/r.proj.html
> First of all let me warn you that I'm new at GRASS :)
> ...keep on. Its worth!
> Regards,
> Achim
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20100118/49b00746/attachment-0001.html
