[GRASS-user] change the cell value of a geotiff
maven apache
apachemaven0 at gmail.com
Wed Jan 20 22:19:15 EST 2010
2010/1/21 Milton Cezar Ribeiro <miltinho.astronauta at gmail.com>
> Hi Maven,
> do you think that if you have min = -1267650600228229401496703205376.000000
> is the same value you used on r.null setnull=-1.26765060022823e+030 ?
Oh ,thanks ,my mistake.
I used the " r.null map=aaa at PERMANENT setnull=-1.267e+30--1.268e+30 "
it seems that it works. And now I am using the r.fillnulls to do the
Interpolation, it has taken a long time. :(
IS the tension and smooth parameter shoudle be configed?
> I think following the Hamish's suggestion you will get there :-)
> bests
> milton
> 2010/1/20 maven apache <apachemaven0 at gmail.com>
>> 2010/1/21 Hamish <hamish_b at yahoo.com>
>> maven apache wrote:
>>> > I have a geotiff now, and some cells have a not-expected
>>> > value, so I want to Interpolation them, and I notice that
>>> > there is a command named r.fillnull, however the cell to be
>>> > changed is not null, so I want to :
>>> > 1) change the special cell value to null
>>> > 2) use the r.fillnull to Interpolation.
>>> > The problem is I do not know how to do the step 1 with
>>> > grass, anyone can do me a favor?
>>> try r.null.
>>> Hamish
>>> Hi;
>> It seems that the r.null does not work.
>> 1) I use the r.info to get the info of the tiff which I have imported to
>> grass and I got that:
>> Hi:
>> (Thu Jan 21 09:56:46
>> 2010)
>> r.info map=aaa at PERMANENT
>> | Layer: aaa at PERMANENT Date: Tue Jan 12 16:02:39
>> 2010 |
>> | Mapset: PERMANENT Login of Creator:
>> Administrator |
>> | Location:
>> hdf5loc |
>> | DataBase:
>> D:\GrassDataBase |
>> | Title: ( aaa
>> | Timestamp:
>> none |
>> | Type of Map: raster Number of Categories:
>> 499 |
>> | Data Type:
>> FCELL |
>> | Rows:
>> 720 |
>> | Columns:
>> 1440 |
>> | Total Cells:
>> 1036800 |
>> | Projection:
>> Latitude-Longitude |
>> | N: 90N S: 90S Res:
>> 0:15 |
>> | E: 180E W: 180W Res:
>> 0:15 |
>> | Range of data: min = -1267650600228229401496703205376.000000 max
>> = 4 |
>> | Data
>> Description: |
>> | generated by
>> r.in.gdal |
>> Comments: |
>> | r.in.gdal input="D:\data\hdf5\aaa.tif"
>> output="aaa" |
>> (Thu Jan 21 09:56:47 2010) Command finished (0
>> sec)
>> (Thu Jan 21 09:56:50 2010)
>> 2)then I use r.null to set the null value to null: r.null
>> 3) I use the r.info again to see if it is changed :
>> r.info -r map=aaa at PERMANENT
>> min=-1.26765060022823e+030
>> max=498.5
>> (Thu Jan 21 09:56:50 2010) Command finished (0
>> sec)
>> It seems that the valuse are not changed to null.
>> I wonder why?
>> grass-user mailing list
>> grass-user at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-user
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20100121/7addc027/attachment.html
