[GRASS-user] Re: Help with importing points and their attributes
M S
mseibel at gmail.com
Tue Jan 26 09:06:57 EST 2010
What does 'db.connect -p' show?
Mark
On Tue, Jan 26, 2010 at 9:02 AM, Rebecca Bennett <rabennett at ymail.com> wrote:
> Dear Sela,
> Thank you for your advice. I have re-run the import having corrected the
> format as you suggest, using the command below:
> v.in.ascii -z -n input=/home/rebecca/lidar/08.txt output=test_08_attribute
> format=point {fs= } skip=0 {columns=columns= 'x double precision, y double
> precision, z double precision, i double precision'} x=1 y=2 z=3 cat=0
> --overwrite
> However I now get the error message
> "DBMI-SQLite driver error:
> Unable to open database
> </home/rebecca/Documents/Mapping/Grassdata/Salisbury/PERMANENT/sqlite> by
> driver <sqlite>
> Unable to open database: unable to open database file
> driver <sqlite>"
> so it maybe a problem with my database driver rather than the input file? I
> have a folder called sqlite but no files within it...
> Once again thanks for your help, any more suggestions about how to fix this
> are welcome!
> Rebecca
> View this message in context: http://n2.nabble.com/Help-with-importing-points-and-their-attributes-tp4460359p4460750.html
> Sent from the Grass - Users mailing list archive at Nabble.com.
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
