[GRASS-user] Re: Help with importing points and their attributes
Rebecca Bennett rabennett at ymail.com
Tue Jan 26 09:02:29 EST 2010
Dear Sela,
Thank you for your advice. I have re-run the import having corrected the
format as you suggest, using the command below:
v.in.ascii -z -n input=/home/rebecca/lidar/08.txt output=test_08_attribute
format=point {fs= } skip=0 {columns=columns= 'x double precision, y double
precision, z double precision, i double precision'} x=1 y=2 z=3 cat=0
--overwrite
However I now get the error message
"DBMI-SQLite driver error:
Unable to open database
</home/rebecca/Documents/Mapping/Grassdata/Salisbury/PERMANENT/sqlite> by
driver <sqlite>
Unable to open database: unable to open database file
driver <sqlite>"
so it maybe a problem with my database driver rather than the input file? I
have a folder called sqlite but no files within it...
Once again thanks for your help, any more suggestions about how to fix this
are welcome!
Rebecca
View this message in context: http://n2.nabble.com/Help-with-importing-points-and-their-attributes-tp4460359p4460750.html
Sent from the Grass - Users mailing list archive at Nabble.com.
