[GRASS-user] Re: [GRASS-dev] Compiling r.example in LINUX
António Rocha
antonio.rocha at deimos.com.pt
Tue Jan 26 11:21:23 EST 2010
Hi All
Ok I've changed my ARCH_DISTDIR, ARCH_BINDIR (GRASS.MAKE), GRASS_HOME
and RUN_GISBASE (PLATFORM.MAKE) in order to point to my grass-6.4.0svn
installation instead of my Snapshot folder.
Is it helpful to create a Wiki regarding this matters? (two other
persons sent me PMs regarding this questions with the same questions).
Thank you Glynn for your help.
Best regards,
Antonio
Glynn Clements wrote:
> António Rocha wrote:
>> The thing is that I went here:
>> http://trac.osgeo.org/grass/browser/grass/trunk/doc/raster and I
>> donwloaded the r.example that is there.
>> At least I didn«t saw any information regarding GRASS version :(.
>> Now I realize thatr the trunk relates with 7.0 version and in Branches I
>> can find 6.4 version. :)
>> Ok After I did this:
>> sudo make -C Desktop/GRASS_dvp/r.example/
>> MODULE_TOPDIR=/usr/local/grass-6.4.0svn
>> Instead of putting r.example in /usr/local/grass-6.4.0svn my r.example
>> was putted in
>> /home/anrr/Downloads/grass-6.4.svn_src_snapshot_2010_01_16-2/dist.i686-pc-linux-gnu
>> this is the path to my snapshot from which I installed grass-6.4.0svn.
>> Shouldn't it be placed in usr/local/grass-6.4.0svn? Because altough it
>> has been compiled it's not available to be used.
> The *.make files continue to reflect the build directory; you'll need
> to override certain other variables, e.g. GRASS_HOME and RUN_GISBASE.
> There may be other issues; the ability to build modules outside of the
> source tree against an installed version of GRASS is a relatively
> recent feature, and may still have bugs.
__________ Information from ESET NOD32 Antivirus, version of virus signature database 4807 (20100126) __________
The message was checked by ESET NOD32 Antivirus.
http://www.eset.com
