[GRASS-user] Re: Help with importing points and their attributes
Markus Metz
markus.metz.giswork at googlemail.com
Tue Jan 26 09:30:16 EST 2010
M S wrote:
> Looking at mine, the only difference I see is that the name of the
> database is missing a ".db" extension. Please let me know if that
> makes a difference.
For the sqlite driver, the database must be a file, not a directory. The
GRASS standard is sqlite.db I think. I would delete the folder sqlite
and reset the database connection either with
db.connect driver=sqlite database=$GISDBASE/$LOCATION_NAME/$MAPSET/sqlite.db
or hacking the VAR file (dangerous). In theory, GRASS should create a
new database if not existing.
Hope that helps,
Markus
> Mark
> On Tue, Jan 26, 2010 at 9:09 AM, Rebecca Bennett <rabennett at ymail.com> wrote:
>> Hi Mark
>> db.connect -p shows
>> driver:sqlite
>> database:$GISDBASE/$LOCATION_NAME/$MAPSET/sqlite
>> schema:
>> group:
>> Rebecca
>> View this message in context: http://n2.nabble.com/Help-with-importing-points-and-their-attributes-tp4460359p4460798.html
>> Sent from the Grass - Users mailing list archive at Nabble.com.
>> grass-user mailing list
>> grass-user at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-user
