[GRASS-user] Re: Help with importing points and their attributes
Rebecca Bennett
rabennett at ymail.com
Tue Jan 26 09:34:32 EST 2010
Genius, thanks for that suggestion Mark!
Having changed the database to have a .db at the end I re-ran the import,
getting the following output and error
"Scanning input for column types...
Maximum input row length: 35
Minimum number of columns: 4
Maximum number of columns: 4
DBMI-SQLite driver error:
Error in sqlite3_prepare():
near "=": syntax error
Table <test_08_attribute> linked to vector map <test_08_attribute> does not
exist
Unable to create table: create table test_08_attribute ( cat integer,
columns= 'x double precision, y double precision, z double precision, i
double precision' )"
Does this mean it is not able to create the table now it can see the
database? Any ideas for a fix?
Many thanks
Rebecca
View this message in context: http://n2.nabble.com/Help-with-importing-points-and-their-attributes-tp4460359p4460920.html
Sent from the Grass - Users mailing list archive at Nabble.com.
