[GRASS-user] GRASS scripts manual tab
António Rocha antonio.rocha at deimos.com.pt
Thu Jan 28 14:36:30 EST 2010
Hello Franz
yes. That's right. If you have a description.html in the same folder as
the script, Make will merge Module description with that html file and
create the MANUAL tab.
And that is the MODULE_TOPDIR
Remember you will have to use SUDO and giver permission to run script
file as a script (at least I have to do that).
Best regards
Antonio
> Thank Glynn
> But if I just "write" a script a put it in /Scripts/ I will have to create a
> HTML page and put it   in $GISBASE/docs/html/<scriptname>.html in order to
> have a manual right?
> Regarding Built Scripts using GRASS makefiles, the structure would be
> something like this?
> MODULE_TOPDIR = ../..
> PGM = <SCRIPT NAME>
> include $(MODULE_TOPDIR)/include/Make/Script.make
> default: script
> Thanks you all
__________ Information from ESET NOD32 Antivirus, version of virus signature database 4815 (20100128) __________
The message was checked by ESET NOD32 Antivirus.
http://www.eset.com
