[GRASS-user] Problems Running r.flow
    Hamish
    hamish_b at yahoo.com
    Fri Jan 29 00:14:39 EST 2010
Glynn wrote:
> Try the attached patch. It replaces the exact comparison
> with a check that the resolutions agree to within 1ppm.
> +static int compare_regions(const struct Cell_head *a, const struct Cell_head *b)
> +    return (fabs(a->ew_res - b->ew_res) < 1e-6 * b->ew_res &&
> +        fabs(a->ns_res - b->ns_res) < 1e-6 * b->ns_res);
use GRASS_EPSILON, as it is based on the machine; it doesn't make
assumptions about the units you are measuring in. (or for that matter
that your x and y axes represent "distance" at all, in the way we usually
think about it)
e.g. for Lat/Long 1e-6 is not enough to accurately represent the
region resolution well for sub-meter data. (1e-6*1852*60 => ~ 11cm)
this may not have come up before because the improved reading/writing
at "full" %.15g is rather new*, and the old read-write cycle may have,
as your post suggested, quietly rounded all the problems away.
[*] see task #335,  https://trac.osgeo.org/grass/ticket/335
Hamish
