[GRASS-user] Problems Running r.flow
Rich Shepard
rshepard at appl-ecosys.com
Fri Jan 29 08:50:37 EST 2010
On Fri, 29 Jan 2010, Glynn Clements wrote:
> With g.region, if you use the -a switch and/or the align= option, the
> bounds will be adjusted so that the height/width is equal to the
> resolution multiplied by the number of rows/columns.
> Regardless of which options are used, the final step will recalculate
> the resolution as above. If you used the -a switch or the align=
> option, this final recalculation should have no effect, although in
> practice it may adjust the resolution by a miniscule amount.
Thanks, Glynn.
Rich
