[GRASS-user] Re: grass environment script
maven apache
apachemaven0 at gmail.com
Sun Jan 31 21:28:37 EST 2010
2010/1/31 Glynn Clements <glynn at gclements.plus.com>
> maven apache wrote:
> > In fact , I wonder if I can set the variables in the .grassrc to the
> path,
> > then I can work without the .grassrc?
> No.
> > $HOME/.grassrc6s tores the GRASS variables (but not environment
> variables)Note
> > this, is there any differences between grass variables and envrionment
> > viriables?
> Yes, there's quite a lot of difference between them.
> Environment variables are implemented by the operating system. Each
> process has its own set of environment variables, which are inherited
> from its parent.
> So , I want to know if I can set all of them to the path environment
variables?
> GRASS variables are implemented by the GRASS libraries, and stored in
> the file referenced by the GISRC environment variable.
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20100201/095533e2/attachment.html
