[GRASS-user] Re: grass-user Digest, Vol 51, Issue 6
Luigi Ponti
lponti at inbox.com
Mon Jul 5 17:17:29 EDT 2010
Dear Daniel,
I have a one-month-old (apologize) wingrass 6.4.svn installed from
http://josef.fsv.cvut.cz/wingrass/ on windows7.
> Date: Mon, 5 Jul 2010 17:11:39 -0300
> From: Daniel Victoria <daniel.victoria at gmail.com>
> [...] Opening a separate MSys console
> and executing /grass/bin/grass64svn will start the Select location
> window and after I click on Start, Grass crashes with the following
> error:
> $ grass64svn
> Cleaning up temporary files ...
> Starting GRASS ...
> ATENÇÃO: Attention!
> ATENÇÃO: Locking is not supported on Windows!
> __________ ___ __________ _______________
> / ____/ __ \/ | / ___/ ___/ / ____/ _/ ___/
> / / __/ /_/ / /| | \__ \\_ \ / / __ / / \__ \
> / /_/ / _, _/ ___ |___/ /__/ / / /_/ // / ___/ /
> \____/_/ |_/_/ |_/____/____/ \____/___//____/
> Welcome to GRASS 6.4.0svn (2010)
> GRASS homepage: http://grass.osgeo.org/
> This version running thru: GNU Bash (Cygwin) (/usr/bin/bash.exe)
sounds like you are running through Cygwin ("GNU Bash (Cygwin)
(/usr/bin/bash.exe)") -- on my machine the MSys desktop link triggers a
welcome screen that at the same line says "Bourne Shell (/bin/sh)" (and
everything works as expected including the wxpython GUI):
Starting GRASS ...
ATTENZIONE: Attention!
ATTENZIONE: Locking is not supported on Windows!
This version running thru: Bourne Shell (/bin/sh)
Help is available with the command: g.manual -i
See the licence terms with: g.version -c
If required, restart the GUI with: g.gui wxpython
When ready to quit enter: exit
GRASS 6.4>
Do you by any chance have Cygwin bash.exe on your %PATH% environmental
variable?
As for the Python errors you mention, I am not sure but it may again be
a problem related to %PATH% settings. It is indeed possible to have
heritage Cygwin/GRASS and the new native Wingrass running on the same
machine, but care must be taken to avoid messing with the global %PATH%.
As for running R from GRASS, an approach I have found useful is to
follow the advice by Glynn Clements, i.e. not running GRASS from MSys
but instead use a simple DOS box started via a batch file that sets
required environmental variables to run GRASS, and then call the shell
executable sh.exe (shell scripts designed for Cygwin/GRASS run with
minimal adjustments -- mostly to cope with MSys path conventions
issues). Glynn has taken on this topic in a growing (thanks for your
patience, Glynn!) number of posts -- see for example:
http://osgeo-org.1803224.n2.nabble.com/grass-start-bat-in-windows-tp4492202p4492202.html
Finally, when I have my GRASS-enabled DOS box, I just type R (of course
R needs to be in the %PATH%) and I am pretty much done.
I hope this helps and sorry if I misunderstood your questions,
Luigi
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20100705/e8ab71ed/attachment.html
