[GRASS-user] Re: Wingrass 6.4 with MSYS does not work
Daniel Victoria
daniel.victoria at gmail.com
Mon Jul 5 20:59:51 EDT 2010
I just installed WinGrass in my home WinXP box and it's working fine.
It also gives me the "Bourne Shell (/bin/sh)" line as reported by
Luigi, instead of the ("GNU Bash (Cygwin) (/usr/bin/bash.exe)") I saw
at my Win7 box. So chances are my Win7 has some left over cygwin
installation and a messed up %PATH%. Will look into that tomorrow
morning.
Cheers and thanks
Daniel
On Mon, Jul 5, 2010 at 8:03 PM, Daniel Victoria
<daniel.victoria at gmail.com> wrote:
> It could be that I have some Cygwin install left over. I also have
> python(x,y) installed but don't think that is what is messing with
> WinGrass. I will take a look at my path environmental variables and
> post an update tomorrow.
> Thanks
> daniel
> On Mon, Jul 5, 2010 at 6:19 PM, Luigi Ponti <quartese at gmail.com> wrote:
>> ...sorry: reposting with a decent subject line...
>> Dear Daniel,
>> I have a one-month-old (apologize) wingrass 6.4.svn installed from
>> http://josef.fsv.cvut.cz/wingrass/ on windows7.
>> Date: Mon, 5 Jul 2010 17:11:39 -0300
>> From: Daniel Victoria <daniel.victoria at gmail.com>
>> [...] Opening a separate MSys console
>> and executing /grass/bin/grass64svn will start the Select location
>> window and after I click on Start, Grass crashes with the following
>> error:
>> $ grass64svn
>> Cleaning up temporary files ...
>> Starting GRASS ...
>> ATENÇÃO: Attention!
>> ATENÇÃO: Locking is not supported on Windows!
>> __________ ___ __________ _______________
>> / ____/ __ \/ | / ___/ ___/ / ____/ _/ ___/
>> / / __/ /_/ / /| | \__ \\_ \ / / __ / / \__ \
>> / /_/ / _, _/ ___ |___/ /__/ / / /_/ // / ___/ /
>> \____/_/ |_/_/ |_/____/____/ \____/___//____/
>> Welcome to GRASS 6.4.0svn (2010)
>> GRASS homepage: http://grass.osgeo.org/
>> This version running thru: GNU Bash (Cygwin)
>> (/usr/bin/bash.exe)
>> sounds like you are running through Cygwin ("GNU Bash (Cygwin)
>> (/usr/bin/bash.exe)") -- on my machine the MSys desktop link triggers a
>> welcome screen that at the same line says "Bourne Shell (/bin/sh)" (and
>> everything works as expected including the wxpython GUI):
>> Starting GRASS ...
>> ATTENZIONE: Attention!
>> ATTENZIONE: Locking is not supported on Windows!
>> This version running thru: Bourne Shell (/bin/sh)
>> Help is available with the command: g.manual -i
>> See the licence terms with: g.version -c
>> If required, restart the GUI with: g.gui wxpython
>> When ready to quit enter: exit
>> GRASS 6.4>
>> Do you by any chance have Cygwin bash.exe on your %PATH% environmental
>> variable?
>> As for the Python errors you mention, I am not sure but it may again be a
>> problem related to %PATH% settings. It is indeed possible to have heritage
>> Cygwin/GRASS and the new native Wingrass running on the same machine, but
>> care must be taken to avoid messing with the global %PATH%.
>> As for running R from GRASS, an approach I have found useful is to follow
>> the advice by Glynn Clements, i.e. not running GRASS from MSys but instead
>> use a simple DOS box started via a batch file that sets required
>> environmental variables to run GRASS, and then call the shell executable
>> sh.exe (shell scripts designed for Cygwin/GRASS run with minimal adjustments
>> -- mostly to cope with MSys path conventions issues). Glynn has taken on
>> this topic in a growing (thanks for your patience, Glynn!) number of posts
>> -- see for example:
>> http://osgeo-org.1803224.n2.nabble.com/grass-start-bat-in-windows-tp4492202p4492202.html
>> Finally, when I have my GRASS-enabled DOS box, I just type R (of course R
>> needs to be in the %PATH%) and I am pretty much done.
>> I hope this helps and sorry if I misunderstood your questions,
>> Luigi
