[GRASS-user] Re: Wingrass 6.4 with MSYS does not work
Daniel Victoria daniel.victoria at gmail.com
Mon Jul 5 19:03:55 EDT 2010
It could be that I have some Cygwin install left over. I also have
python(x,y) installed but don't think that is what is messing with
WinGrass. I will take a look at my path environmental variables and
post an update tomorrow.
Thanks
daniel
On Mon, Jul 5, 2010 at 6:19 PM, Luigi Ponti <quartese at gmail.com> wrote:
> ...sorry: reposting with a decent subject line...
> Dear Daniel,
> I have a one-month-old (apologize) wingrass 6.4.svn installed from
> http://josef.fsv.cvut.cz/wingrass/ on windows7.
> Date: Mon, 5 Jul 2010 17:11:39 -0300
> From: Daniel Victoria <daniel.victoria at gmail.com>
> [...] Opening a separate MSys console
> and executing /grass/bin/grass64svn will start the Select location
> window and after I click on Start, Grass crashes with the following
> error:
> $ grass64svn
> Cleaning up temporary files ...
> Starting GRASS ...
> ATENÇÃO: Attention!
> ATENÇÃO: Locking is not supported on Windows!
>           __________  ___   __________    _______________
>          / ____/ __ \/   | / ___/ ___/   / ____/  _/ ___/
>         / / __/ /_/ / /| | \__ \\_  \   / / __ / / \__ \
>        / /_/ / _, _/ ___ |___/ /__/ /  / /_/ // / ___/ /
>        \____/_/ |_/_/  |_/____/____/   \____/___//____/
> Welcome to GRASS 6.4.0svn (2010)
> GRASS homepage:                          http://grass.osgeo.org/
> This version running thru:               GNU Bash (Cygwin)
> (/usr/bin/bash.exe)
> sounds like you are running through Cygwin ("GNU Bash (Cygwin)
> (/usr/bin/bash.exe)") -- on my machine the MSys desktop link triggers a
> welcome screen that at the same line says "Bourne Shell (/bin/sh)" (and
> everything works as expected including the wxpython GUI):
> Starting GRASS ...
> ATTENZIONE: Attention!
> ATTENZIONE: Locking is not supported on Windows!
> This version running thru:               Bourne Shell (/bin/sh)
> Help is available with the command:      g.manual -i
> See the licence terms with:              g.version -c
> If required, restart the GUI with:       g.gui wxpython
> When ready to quit enter:                exit
> GRASS 6.4>
> Do you by any chance have Cygwin bash.exe on your %PATH% environmental
> variable?
> As for the Python errors you mention, I am not sure but it may again be a
> problem related to %PATH% settings. It is indeed possible to have heritage
> Cygwin/GRASS and the new native Wingrass running on the same machine, but
> care must be taken to avoid messing with the global %PATH%.
> As for running R from GRASS, an approach I have found useful is to follow
> the advice by Glynn Clements, i.e. not running GRASS from MSys but instead
> use a simple DOS box started via a batch file that sets required
> environmental variables to run GRASS, and then call the shell executable
> sh.exe (shell scripts designed for Cygwin/GRASS run with minimal adjustments
> -- mostly to cope with MSys path conventions issues). Glynn has taken on
> this topic in a growing (thanks for your patience, Glynn!) number of posts
> -- see for example:
> http://osgeo-org.1803224.n2.nabble.com/grass-start-bat-in-windows-tp4492202p4492202.html
> Finally, when I have my GRASS-enabled DOS box, I just type R (of course R
> needs to be in the %PATH%) and I am pretty much done.
> I hope this helps and sorry if I misunderstood your questions,
> Luigi
