[GRASS-user] Error while using r.in.gdal for USGS landsat7 images
António Rocha
antonio.rocha at deimos.com.pt
Thu Jul 8 09:04:24 EDT 2010
Hello Markus
I have just tested that and it seems to be the best solution. But in
this case I didn't know that it was all set to north.
Markus Neteler wrote:
> 2010/7/7 António Rocha <antonio.rocha at deimos.com.pt>:
>> Hi there,
>> I'm using r.in.gdal to import Landsat7 images downloaded from USGS website.
>> These landsat images are distributed in UTM-WGS84 for the specific zone. in
>> this case I'm working with images from Brazil (WGS84 UTM ZONE 24S). So first
>> I created an Location based on EPSG:32724.
>> Here goes the gdalinfo command for the image:
>> /Driver: GTiff/GeoTIFF
>> Files: L5216065_06520070405_B10.TIF
>> Size is 8171, 6991
>> Coordinate System is:
>> PROJCS["WGS 84 / UTM zone 24N",
>> As can be seen it's North instead of South. Nevertheless, r.in.gdal imports
>> it and it even says: Projection of input dataset and current location appear
>> to match
> but only appear I think - it is a garbage in/garbage out problem.
> I would assign the correct EPSG code with
> gdal_translate -a_srs ... badfile.tif goodfile.tif
> then reimport. To catch all possible (rare) nonsense case in r.in.gdal I
> consider to be overkill.
> Markus
> __________ Information from ESET NOD32 Antivirus, version of virus signature database 5261 (20100708) __________
> The message was checked by ESET NOD32 Antivirus.
> http://www.eset.com
http://www.eset.com
