[GRASS-user] v.in.gpsbabel-2
Hamish
hamish_b at yahoo.com
Fri Jul 9 11:45:52 EDT 2010
Bulent wrote:
> I am back with another issue, again ' v.in.gpsbabel' module!
> My GPS unit records data in UTM projection with WGS84 datum. I
> just attempted to import the waypoints into GRASS using a
> Garmin MapSource text (tab delimited) file.
$ gpsbabel --help | grep -i garmin
garmin301 Garmin 301 Custom position and heartrate
glogbook Garmin Logbook XML
gdb Garmin MapSource - gdb
mapsource Garmin MapSource - mps
garmin_txt Garmin MapSource - txt (tab delimited)
pcx Garmin PCX5
garmin_poi Garmin POI database
garmin Garmin serial/USB protocol
gtrnctr Garmin Training Centerxml
try the "garmin_txt" format.
also if it is just tab delimited you can use v.in.ascii with the appropriate number of skip lines and column numbers. that's a lot
more robust than the gpsbabel method.
> I did not check -k flag (do not transform from WGS84).
that means lat/lon wgs84 by the way, not just the wgs84 datum.
Hamish
