[GRASS-user] v.in.gpsbabel-3
Bulent Arikan
bulent.arikan at gmail.com
Fri Jul 9 14:00:19 EDT 2010
Thanks for all the replies. It seems that I forgot to specify the format (
_txt) in the Required tab. So, it fixed the problem and now I can import all
the waypoints and tracks. However, I am puzzled with one detail. As I
- I set my GPS unit to record measurements in UTM,
- the text file prepared by GPS Babel has header showing UTM as projection,
- even if I specify the projection parameter according to PROJ.4 in the
Required tab of the module,
the attribute tables for the resultant waypoint and track vector files are
in lat/long format. How can this happen? I never work with lat/long.
BÜLENT
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20100709/0aba2c99/attachment.html
