[GRASS-user] Arc Binary coverages- arggg!
Mark Seibel
mseibel at gmail.com
Mon Jul 12 20:02:02 EDT 2010
That's what I figured. Then I am fairly sure this is what you're
after, http://grass.osgeo.org/grass64/manuals/html64_user/v.in.ogr.html.
Arc Vector coverages are stored in 2 directories. One for geometry
(the directory is the name of the coverage) and the database is
contained in an 'info' directory. The examples below are not clear to
me how it addresses this, but it does state it will do it. I could
try some testing tomorrow if not figured out by then.
# Arc Coverage
We import the Arcs and Label points, the module takes care to build areas:
v.in.ogr dsn=gemeinden layer=LAB,ARC type=centroid,boundary output=mymap
# E00 file (see also v.in.e00)
First we have to convert the E00 file to an Arc Coverage with
'avcimport' (AVCE00 tools, use e00conv first in case that avcimport
fails):
avcimport e00file coverage
v.in.ogr dsn=coverage layer=LAB,ARC type=centroid,boundary output=mymap
All the best.
Mark
On Mon, Jul 12, 2010 at 7:47 PM, stephen sefick <ssefick at gmail.com> wrote:
> Vector Coverages.
> On Mon, Jul 12, 2010 at 6:41 PM, Mark Seibel <mseibel at gmail.com> wrote:
>> Are these vector coverages or raster datasets?
>> Mark
>> On Jul 12, 2010, at 6:08 PM, stephen sefick <ssefick at gmail.com> wrote:
>>> I have a couple of files that are in this format...
>>> aat.adf arx.adf dbltic.adf metadata.xml prj.adf txx.adf
>>> arc.adf dblbnd.adf log par.adf txt.adf
>>> they are arc binary data correct. Is there anyway I can use these
>>> with GRASS or QGIS?
>>> Stephen Sefick
>>> ____________________________________
>>> | Auburn University |
>>> | Department of Biological Sciences |
>>> | 331 Funchess Hall |
>>> | Auburn, Alabama |
>>> | 36849 |
>>> |___________________________________|
>>> | sas0025 at auburn.edu |
>>> | http://www.auburn.edu/~sas0025 |
>>> Let's not spend our time and resources thinking about things that are
>>> so little or so large that all they really do for us is puff us up and
>>> make us feel like gods. We are mammals, and have not exhausted the
>>> annoying little problems of being mammals.
>>> -K. Mullis
>>> grass-user mailing list
>>> grass-user at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/grass-user
> Stephen Sefick
> | Auburn University |
> | 331 Funchess Hall |
> | Auburn, Alabama |
> | 36849 |
> -K. Mullis
