[GRASS-user] Beginner (Mac): How do I display a raster in Map
Display window using line commands
Etienne DELAY (deust 2010)
etienne.delay at etu.unilim.fr
Wed Jul 14 03:25:29 EDT 2010
Hamish,
> Ahhh, yes I did try using an X-monitor earlier. It worked for raster display as you suggest. But when I tried to use "zoom" commands, I found that my Kensington Orbit trackball would not release the cursor to finish selecting the zoom area. Do I have to change the behavior of my right and left buttons?
> I suspect I will have to create my map exercises twice: once in X-monitor to learn about line commands, and again in the GUI to create the actual map and have more control over layers. Is this the type of difficulty I should expect from GRASS on a Mac?
> Thanks.
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
Hi Syncrasy,
I work on a Mac and I found an alternative, I do background work on
GRASS, but once I want to do the layout, I go into Qgis to directly
integrate the work of grass ...
Cordialement
Etienne DELAY
Deust "Webmaster et gest. d'intranet" (IDSkype : etienne.delay.tic)
Master IUP "valorisation du patrimoine et aménagement du territoire"
-------------- section suivante --------------
Une pi?ce jointe HTML a ?t? enlev?e...
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20100714/16e2a474/attachment-0001.html
