[GRASS-user] Re: r.out.gdal output size vs input size
LeeDaniel Lee.Daniel.1986 at gmail.com
Wed Jul 14 05:51:43 EDT 2010
In my opinion, the easiest way would be to set the region according to your
GeoTIFF. You can do that with g.region using the parameter rast=your_raster
More here:
http://grass.itc.it/gdp/html_grass64/g.region.html
If you set the region to your GeoTIFF, the extent and resolution of the
region will match its original specifications so your output file should be
~ the same size as the original :)
View this message in context: http://osgeo-org.1803224.n2.nabble.com/r-out-gdal-output-size-vs-input-size-tp5291740p5291817.html
Sent from the Grass - Users mailing list archive at Nabble.com.
