[GRASS-user] Re: r.out.gdal output size vs input size
Espen Isaksen espen.isaksen at gmail.com
Wed Jul 14 05:53:02 EDT 2010
Thanks LeeDaniel, that is what I figured too :-) I am still a bit new
to Grass so I have to get used to this region stuff.
Espen
2010/7/14 LeeDaniel <Lee.Daniel.1986 at gmail.com>:
> In my opinion, the easiest way would be to set the region according to your
> GeoTIFF. You can do that with g.region using the parameter rast=your_raster
> More here:
> http://grass.itc.it/gdp/html_grass64/g.region.html
> If you set the region to your GeoTIFF, the extent and resolution of the
> region will match its original specifications so your output file should be
> ~ the same size as the original :)
> View this message in context: http://osgeo-org.1803224.n2.nabble.com/r-out-gdal-output-size-vs-input-size-tp5291740p5291817.html
> Sent from the Grass - Users mailing list archive at Nabble.com.
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
