[GRASS-user] compiling grass 7 external modules
Glynn Clements
glynn at gclements.plus.com
Thu Jul 15 22:08:49 EDT 2010
Jarek Jasiewicz wrote:
> In GRASS65 I create dir in raster or vector directory, program module
> in I want to create, next make, sudo make install, ready
> in grass 7 not.
> after make install: "no rules to make install. Stop". Of course make
> goes well, without warnings and errors, objects are created in OBJ.xxx
> directory etc.
> The same repeats when I do "make install" in any module directory which
> I change it for my purposes.
GRASS 7 doesn't have "install" targets. These were only added to 6.x
quite recently, and haven't been sync'd to 7.0 (the build system has
changed a lot between 6.x and 7.0).
You can use e.g.:
make ... ARCH_DISTDIR=...
to cause the output file(s) to be created somewhere other than the
dist.<arch> directory; ARCH_DISTDIR should refer to the base directory
of the GRASS installation, i.e. $GISBASE.
