[GRASS-user] compiling grass 7 external modules
Jarek Jasiewicz
jarekj at amu.edu.pl
Fri Jul 16 00:08:20 EDT 2010
> GRASS 7 doesn't have "install" targets. These were only added to 6.x
> quite recently, and haven't been sync'd to 7.0 (the build system has
> changed a lot between 6.x and 7.0).
> You can use e.g.:
> make ... ARCH_DISTDIR=...
> to cause the output file(s) to be created somewhere other than the
> dist.<arch> directory; ARCH_DISTDIR should refer to the base directory
> of the GRASS installation, i.e. $GISBASE.
Glynn!
Thanks for explanation.
Jarek
