[GRASS-user] Some issues with wxGUI
Venkatesh Raghavan
raghavan at media.osaka-cu.ac.jp
Fri Jul 16 22:37:43 EDT 2010
Hi all,
While using GRASS 6.4.svn stable snapshot MS Windows
binaries GRASS6.4.0SVN-r42743-1 from
http://josef.fsv.cvut.cz/wingrass/grass64/ and
also with WinGRASS-6.4.0RC6-1
The following problems were reported by tester in Japan
using wxGUI both in Japanese and English language
1. Cannot erase a map in Map Display by unchecking the checkbox in
Layer Manager and re-rendering map.
2. Command "r.mfilter", "r.mapcalculator" and "r.colors.rules" are
activated only by typing them into Cmd>
3. Cannot erase a map in Map Display by unchecking the checkbox in
4. Cannot run commands when I display any maps. Need to check
"menuform.py".
are others experiencing same issue? Any fix for the above
available?
Thanks in advance.
Venka
