[GRASS-user] Re: import wx
William Kyngesburye
woklist at kyngchaos.com
Tue Jul 20 10:08:28 EDT 2010
On Jul 20, 2010, at 2:39 AM, schorschli wrote:
> I updated to version GRASS 6.4rc6. But now I cannot start grass anymore...
> File "/Applications/GRASS-6.4.app/Contents/MacOS/etc/wxpython/wxgui.py",
> line 1819, in <module>
> sys.exit(main())
> line 1812, in main
> app = GMApp(workspaceFile)
> line 1737, in __init__
> wx.App.__init__(self, False)
> File
> "/Users/Shared/unix/wxpython-leo/lib/python2.5/site-packages/wx-2.8-mac-unicode/wx/_core.py",
> line 7978, in __init__
> File
> line 7552, in _BootstrapApp
> line 1748, in OnInit
> introBmp = introImage.ConvertToBitmap()
> File
> line 3369, in ConvertToBitmap
> wx._core.PyAssertionError: C++ assertion "image.Ok()" failed at
> ../src/mac/carbon/bitmap.cpp(1286) in wxBitmap(): invalid image
This has happened before in development versions. I thought I had it figured out as some combination of wxpython and image colorspace, but now I can't get it to work. It works on OS X Snow Leopard. The only difference there is Python 2.5 (Leopard) vs 2.6 (Snow). Using Python 2.6 on Leopard isn't practical.
I need to look into this...
> '/Users/lucaurbani/Documents/code/python_scripts/park_fahrtenberechnung'
> '/Library/Frameworks/SQLite3.framework/Versions/3/Python'
> '/Library/Frameworks/GDAL.framework/Versions/1.6/Python/site-packages'
> '/Library/Frameworks/cairo.framework/Versions/1/Python'
> '/Applications/GRASS-6.4.app/Contents/MacOS/etc/python'
> '/System/Library/Frameworks/Python.framework/Versions/2.5/lib/python25.zip'
> '/System/Library/Frameworks/Python.framework/Versions/2.5/lib/python2.5'
> '/System/Library/Frameworks/Python.framework/Versions/2.5/lib/python2.5/plat-darwin'
> '/System/Library/Frameworks/Python.framework/Versions/2.5/lib/python2.5/plat-mac'
> '/System/Library/Frameworks/Python.framework/Versions/2.5/lib/python2.5/plat-mac/lib-scriptpackages'
> '/System/Library/Frameworks/Python.framework/Versions/2.5/Extras/lib/python'
> '/System/Library/Frameworks/Python.framework/Versions/2.5/lib/python2.5/lib-tk'
> '/System/Library/Frameworks/Python.framework/Versions/2.5/lib/python2.5/lib-dynload'
> '/Library/Python/2.5/site-packages'
> '/usr/local/lib/wxPython-unicode-2.8.10.1/lib/python2.5'
> '/System/Library/Frameworks/Python.framework/Versions/2.5/Extras/lib/python/PyObjC'
> Any ideas what could be wrong (Maybe
> '/usr/local/lib/wxPython-unicode-2.8.10.1/lib/python2.5')?
GRASS path is before that, so it should not be a problem. From the error above, it's now using the embedded wxpython.
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
[Trillian] What are you supposed to do WITH a maniacally depressed robot?
[Marvin] You think you have problems? What are you supposed to do if you ARE a maniacally depressed robot? No, don't try and answer, I'm 50,000 times more intelligent than you and even I don't know the answer...
- HitchHiker's Guide to the Galaxy
