[GRASS-user] Re: Importing Dems with r.in.xyz
Markus Metz
markus.metz.giswork at googlemail.com
Mon Jun 7 06:57:36 EDT 2010
> g.region -p
north: -49312.5
south: -74587.5
west: -3015862.5
east: -2987512.5
nsres: 25
ewres: 25
rows: 1011
cols: 1134
cells: 1146474
>From the region settings you posted previously, I assume that the 1.
column is north and the 2. is east, so:
> r.in.xyz input=2728AB.ort.grass output=2728AB.ort fs=, x=2 y=1
r.in.xyz complete. 1146370 points found in region.
> r.univar map=2728AB.ort
total null and non-null cells: 1146474
total null cells: 104
Of the non-null cells:
n: 1146370
minimum: 1473.52
maximum: 1618.85
range: 145.33
mean: 1519.76
mean of absolute values: 1519.76
standard deviation: 26.6106
variance: 708.125
variation coefficient: 1.75098 %
sum: 1742202717.5849609375
Everything looks ok.
Markus M
On Mon, Jun 7, 2010 at 12:33 PM, Hanlie Pretorius
<hanlie.pretorius at gmail.com> wrote:
> 2010/6/7, Hamish <hamish_b at yahoo.com>:
>> Hanlie Pretorius wrote:
>>> > I don't think it's this bug because this bug discards only one line of
>>> > data. I don't get any data in because the number of coordinate pairs
>>> > in the file is less than the number of cells in the defined region.
>> Markus Metz:
>>> Weird. In 6.4, r.in.xyz does import a file where the number of
>>> coordinate pairs is far less than the number of cells in the defined
>>> region. (I just did a simple test with two input lines and a region
>>> with 26.5 million cells, got clean import and correct result)
>> sorry, I'm not really grasping what the problem is. If you suspect
>> there is something weird going on can you make the .xyz.bz2 file
>> available for me to download, and supply the output of r.univar
>> `wc -l` and `r.in.xyz --verbose`?
>> Hamish
> Ok, the text file (6.1MB compressed) that I use as input to r.in.xyz
> is available at:
> http://www.nedbib.za.net/dems/
> Output of r.in.xyz --verbose:
> Reading data ...
> Writing to map ...
> r.in.xyz complete. 0 points found in region.
> Output of r.univar:
> total null cells: 1146474
> n: 0
> minimum: -nan
> maximum: -nan
> range: -nan
> mean: -nan
> mean of absolute values: -nan
> standard deviation: -nan
> variance: -nan
> variation coefficient: -nan %
> sum: 0
> output of wc -l:
> 1146370
> Output of r.info:
> | Layer: dem_2728ab_25m Date: Mon Jun 7 12:09:34 2010
> | Mapset: PERMANENT Login of Creator: hanlie
> | Location: sa_tm_29deg_E
> | DataBase: /media/0847147784/grassdata
> | Title: Raw x,y,z data binned into a raster grid by cell mean ( dem_2728
> | Timestamp: none
> | Type of Map: raster Number of Categories: 255
> | Data Type: FCELL
> | Rows: 1011
> | Columns: 1134
> | Total Cells: 1146474
> | Projection: Transverse Mercator
> | N: -49312.5 S: -74587.5 Res: 25
> | E: -2987512.5 W: -3015862.5 Res: 25
> | Range of data: min = -nan max = -nan
> | Data Source:
> | /media/0847147784/data/CD-NGI/DEMS/25m dems/2728/ab/2728AB.ort.grass
> | Data Description:
> | generated by r.in.xyz
> | Comments:
> | r.in.xyz input="/media/0847147784/data/CD-NGI/DEMS/25m dems/2728/ab/\
> | 2728AB.ort.grass" output="dem_2728ab_25m" method="mean" type="FCELL"\
> | x=1 y=2 z=3 zscale=1.0 percent=100
> Thanks
> Hanlie
