[GRASS-user] Build error: 6.5 SVN code
Nikos Alexandris
nikos.alexandris at felis.uni-freiburg.de
Wed Jun 9 19:27:54 EDT 2010
Rich Shepard:
> I've been building the latest SVN code for 6.4 and 6.5 here without any
> errors. Today I get this:
> Started compilation: Wed Jun 9 15:21:25 PDT 2010
> Errors in:
> /usr4/grass65/gui/wxpython/scripts
> In case of errors please change into the directory with error and run
> 'make'.
> If you get multiple errors, you need to deal with them in the order they
> appear in the error log. If you get an error building a library, you will
> also get errors from anything which uses the library.
> Finished compilation: Wed Jun 9 16:06:33 PDT 2010
> make: *** [default] Error 1
> Yet when I follow the directions I cannot run make from that directory:
> [rshepard at salmo /usr4/grass65]$ cd gui/wxpython/scripts/
> [rshepard at salmo /usr4/grass65/gui/wxpython/scripts]$ make
> make: *** No targets specified and no makefile found. Stop.
> Suggestions?
Not specifically to the "failing-to-compile" script. But if you don't need the
GUI, I guess you can go ahead and compile from the root directory as always.
GRASS should work and only "miss" these wxpython scripts.
In case you require the GUI... no idea.
Nikos
