[GRASS-user] Build error: 6.5 SVN code
Rich Shepard rshepard at appl-ecosys.com
Wed Jun 9 19:13:09 EDT 2010
   I've been building the latest SVN code for 6.4 and 6.5 here without any
errors. Today I get this:
Started compilation: Wed Jun  9 15:21:25 PDT 2010
Errors in:
/usr4/grass65/gui/wxpython/scripts
In case of errors please change into the directory with error and run
'make'.
If you get multiple errors, you need to deal with them in the order they
appear in the error log. If you get an error building a library, you will
also get errors from anything which uses the library.
Finished compilation: Wed Jun  9 16:06:33 PDT 2010
make: *** [default] Error 1
   Yet when I follow the directions I cannot run make from that directory:
[rshepard at salmo /usr4/grass65]$ cd gui/wxpython/scripts/
[rshepard at salmo /usr4/grass65/gui/wxpython/scripts]$ make
make: *** No targets specified and no makefile found.  Stop.
Suggestions?
Rich
