[GRASS-user] Re: Import GRIB files to GRASS
António Rocha antonio.rocha at deimos.com.pt
Fri Jun 11 07:34:24 EDT 2010
Hi all
Well, since I'm only evaluating (for now) how to import GRIB's into
GRASS, I wanted to test the r.region solution.
Can anyone describe me what to do regarding that suggestion?
Hamish, about the patch, I'm using GDAL1.7 so I cannot apply your patch.
I'm going to reply on this in GDAL bug tracker.
Thanks
>     It is so interesting to see vastly different approaches to solve a
> similar problem.  I'm downloading NOAA forecast data which is in GRIB
> format.  I run the files through degrib and then parse the shape files with
> a C program using the shapelib libraries and create a new shape file which I
> import into GRASS with v.in.ogr.  I plot the values with d.vect.thematic.
>     The resulting maps can be viewed at:
> http://www.ars.usda.gov/npa/marc/heatstress
>     That reminds me, I originally set up a location for each region with an
> eye forward on multithreading the map generation phases.  I forgot the
> reason in the middle of the project and created several regions in one
> location.  I had to revert back to a location for each region when I
> implemented multithreading but reduced the total map generation time from
> several hours to 15 minutes.   :-)
> Randy
__________ Information from ESET NOD32 Antivirus, version of virus signature database 5189 (20100611) __________
The message was checked by ESET NOD32 Antivirus.
http://www.eset.com
