[GRASS-user] Using addon: r.seg
Nikos Alexandris
nikos.alexandris at felis.uni-freiburg.de
Sun Jun 13 13:16:45 EDT 2010
> katrin eggert wrote:
> > Last week someone mentioned at this mailing list the r.seg segmentation
> > from here: http://www.ing.unitn.it/~grass/)
> > I have contacted the author but he didn't replied. Have anyone ever used?
> > or know someone that have used? :)
Sorry, I've missed one line while copy-pasting...
On Sunday 13 of June 2010 18:48:55 Nikos Alexandris wrote:
> I've came across 2 problems:
> 1. I can't get in installed (using grass64 from svn). The compilation
> seems to run fine (so it should be usable) but after that, when I try to
> "sudo make install" I get the error:
> "make: *** No rule to make target `install'. Stop."
> 2. Running the compiled grass64 (which contains the compiled r.seg) and
> trying to test r.seg gives this error:
--8<---
> "r.seg in_g=mod07_b2 in_u_z=mod07_b2 out=mod07_b2_seg out_u=mod07_b2_seg_u
> out_z=mod07_b2_seg_z
Sorry, <out=> is ambiguous"
--->8--
> I think (after reading the details in the respective presentation) these
> inputs and defined outputs should be enough for the module to run. No luck
> though.
Nikos
