[GRASS-user] Compiling r.seg
    katrin eggert
    katrineggert1980 at gmail.com
    Thu Jun 17 07:22:54 EDT 2010
Hi there
I have tried to compile r.seg, a Segmentation developed by Trento
University. I Know this is not part of GRASS6.4 and not even an addon but
can you help me on this? (where I got the module
http://www.ing.unitn.it/~grass/)
This is the command:sudo make -C r.seg
MODULE_TOPDIR=/usr/local/grass-6.4.0svn
The output:
make: Entering directory `/home/knrr/Desktop/GRASS_dvp/r.seg'
aseglib
make[1]: Entering directory `/home/knrr/Desktop/GRASS_dvp/r.seg/aseglib'
make[1]: Leaving directory `/home/knrr/Desktop/GRASS_dvp/r.seg/aseglib'
src
make[1]: Entering directory `/home/knrr/Desktop/GRASS_dvp/r.seg/src'
gcc -L/usr/local/grass-6.4.0svn/lib -Wl,--export-dynamic
-Wl,-rpath-link,/usr/local/grass-6.4.0svn/lib    -o
/usr/local/grass-6.4.0svn/bin/r.seg OBJ.i686-pc-linux-gnu/main.o  -laseg
-lgrass_gis -lgrass_datetime -lz     -lm  -lz
make htmlcmd
make[2]: Entering directory `/home/knrr/Desktop/GRASS_dvp/r.seg/src'
make /usr/local/grass-6.4.0svn/docs/html/r.seg.html
HTMLSRC=/usr/local/grass-6.4.0svn/bin/r.seg
make[3]: Entering directory `/home/knrr/Desktop/GRASS_dvp/r.seg/src'
if [ "/usr/local/grass-6.4.0svn/bin/r.seg" != "" ] ; then
GISRC=/usr/local/grass-6.4.0svn/demolocation/grassrc64
GISBASE=/usr/local/grass-6.4.0svn PATH="/usr/local/grass-6.4.0svn/bin:$PATH"
LD_LIBRARY_PATH="/usr/local/grass-6.4.0svn/bin:/usr/local/grass-6.4.0svn/lib:"
LC_ALL=C /usr/local/grass-6.4.0svn/bin/r.seg --html-description < /dev/null
| grep -v '</body>\|</html>' > r.seg.tmp.html ; true ; fi
/usr/local/grass-6.4.0svn/tools/mkhtml.sh r.seg ; mkdir -p
/usr/local/grass-6.4.0svn/docs/html ; /usr/bin/install -c  -m 644
r.seg.tmp.html /usr/local/grass-6.4.0svn/docs/html/r.seg.html ; for file in
 *.png *.jpg ; do head -n 1 $file | grep '^#!' > /dev/null ; if [ $? -ne 0 ]
; then /usr/bin/install -c  -m 644 $file /usr/local/grass-6.4.0svn/docs/html
; fi done 2> /dev/null ; true
make[3]: Leaving directory `/home/knrr/Desktop/GRASS_dvp/r.seg/src'
make[2]: Leaving directory `/home/knrr/Desktop/GRASS_dvp/r.seg/src'
make mancmd
make /usr/local/grass-6.4.0svn/man/man1/r.seg.1
MANSRC=/usr/local/grass-6.4.0svn/docs/html/r.seg.html
mkdir -p /usr/local/grass-6.4.0svn/man/man1
GRASS_PERL=/usr/bin/perl VERSION_NUMBER=6.4.0svn sh
/usr/local/grass-6.4.0svn/tools/g.html2man/g.html2man
/usr/local/grass-6.4.0svn/man/man1/r.seg.1 1
sh: Can't open /usr/local/grass-6.4.0svn/tools/g.html2man/g.html2man
make[3]: *** [/usr/local/grass-6.4.0svn/man/man1/r.seg.1] Error 2
make[2]: *** [mancmd] Error 2
make[1]: *** [cmd] Error 2
make[1]: Leaving directory `/home/knrr/Desktop/GRASS_dvp/r.seg/src'
make: Leaving directory `/home/knrr/Desktop/GRASS_dvp/r.seg'
Does it seems to all ok?
At my GRASS binary folder I don't have an executable
(application/x-executable) but a KSeg document (application/x-kseg) that can
be runned from GRASS. Is this normal/expected?
Thanks
Katrin
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20100617/95041f94/attachment.html
