[GRASS-user] Compiling r.seg
Leonardo Hardtke leohardtke at gmail.com
Thu Jun 17 11:46:46 EDT 2010
I compiled r.seg in grass 6.5 (Ubuntu 10.04) but it must be the same in
grass 6.4. Just copy r.seg directory to the raster subdirectory of the
grass source code tree.
cd /usr/local/grass-6.4.0svn/ratster/r.seg
make
when done...
make
sudo make install.
Hope it helps
On 06/17/2010 08:22 AM, katrin eggert wrote:
> Hi there
> I have tried to compile r.seg, a Segmentation developed by Trento
> University. I Know this is not part of GRASS6.4 and not even an addon
> but can you help me on this? (where I got the module
> http://www.ing.unitn.it/~grass/ <http://www.ing.unitn.it/%7Egrass/>)
> This is the command:sudo make -C r.seg
> MODULE_TOPDIR=/usr/local/grass-6.4.0svn
> The output:
> make: Entering directory `/home/knrr/Desktop/GRASS_dvp/r.seg'
> aseglib
> make[1]: Entering directory `/home/knrr/Desktop/GRASS_dvp/r.seg/aseglib'
> make[1]: Leaving directory `/home/knrr/Desktop/GRASS_dvp/r.seg/aseglib'
> src
> make[1]: Entering directory `/home/knrr/Desktop/GRASS_dvp/r.seg/src'
> gcc -L/usr/local/grass-6.4.0svn/lib -Wl,--export-dynamic
> -Wl,-rpath-link,/usr/local/grass-6.4.0svn/lib    -o
> /usr/local/grass-6.4.0svn/bin/r.seg OBJ.i686-pc-linux-gnu/main.o
>  -laseg -lgrass_gis -lgrass_datetime -lz     -lm  -lz
> make htmlcmd
> make[2]: Entering directory `/home/knrr/Desktop/GRASS_dvp/r.seg/src'
> make /usr/local/grass-6.4.0svn/docs/html/r.seg.html
> HTMLSRC=/usr/local/grass-6.4.0svn/bin/r.seg
> make[3]: Entering directory `/home/knrr/Desktop/GRASS_dvp/r.seg/src'
> if [ "/usr/local/grass-6.4.0svn/bin/r.seg" != "" ] ; then
> GISRC=/usr/local/grass-6.4.0svn/demolocation/grassrc64
> GISBASE=/usr/local/grass-6.4.0svn
> PATH="/usr/local/grass-6.4.0svn/bin:$PATH"
> LD_LIBRARY_PATH="/usr/local/grass-6.4.0svn/bin:/usr/local/grass-6.4.0svn/lib:"
> LC_ALL=C /usr/local/grass-6.4.0svn/bin/r.seg --html-description <
> /dev/null | grep -v '</body>\|</html>' > r.seg.tmp.html ; true ; fi
> /usr/local/grass-6.4.0svn/tools/mkhtml.sh r.seg ; mkdir -p
> /usr/local/grass-6.4.0svn/docs/html ; /usr/bin/install -c  -m 644
> r.seg.tmp.html /usr/local/grass-6.4.0svn/docs/html/r.seg.html ; for
> file in  *.png *.jpg ; do head -n 1 $file | grep '^#!' > /dev/null ;
> if [ $? -ne 0 ] ; then /usr/bin/install -c  -m 644 $file
> /usr/local/grass-6.4.0svn/docs/html ; fi done 2> /dev/null ; true
> make[3]: Leaving directory `/home/knrr/Desktop/GRASS_dvp/r.seg/src'
> make[2]: Leaving directory `/home/knrr/Desktop/GRASS_dvp/r.seg/src'
> make mancmd
> make /usr/local/grass-6.4.0svn/man/man1/r.seg.1
> MANSRC=/usr/local/grass-6.4.0svn/docs/html/r.seg.html
> mkdir -p /usr/local/grass-6.4.0svn/man/man1
> GRASS_PERL=/usr/bin/perl VERSION_NUMBER=6.4.0svn sh
> /usr/local/grass-6.4.0svn/tools/g.html2man/g.html2man
> /usr/local/grass-6.4.0svn/man/man1/r.seg.1 1
> sh: Can't open /usr/local/grass-6.4.0svn/tools/g.html2man/g.html2man
> make[3]: *** [/usr/local/grass-6.4.0svn/man/man1/r.seg.1] Error 2
> make[2]: *** [mancmd] Error 2
> make[1]: *** [cmd] Error 2
> make[1]: Leaving directory `/home/knrr/Desktop/GRASS_dvp/r.seg/src'
> make: Leaving directory `/home/knrr/Desktop/GRASS_dvp/r.seg'
> Does it seems to all ok?
> At my GRASS binary folder I don't have an executable
> (application/x-executable) but a KSeg document (application/x-kseg)
> that can be runned from GRASS. Is this normal/expected?
> Thanks
> Katrin
> grass-user mailing list
> grass-user en lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-user
------------ próxima parte ------------
Se ha borrado un adjunto en formato HTML...
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20100617/978e043f/attachment-0001.html
