[GRASS-user] Automatic import ?
    stn
    stneumann at web.de
    Sun Jun 20 17:13:08 EDT 2010
2010/6/19 Martin Landa <landa.martin at gmail.com>
> start GRASS with some location, using
> v.in.ogr location=<newlocation> ...
> you can create new location based on imported data and import data
> into the new location in one command.
Hi all, hi Martin,
thank you, that worked on Ubuntu 10.04 with GRASS GIS 6.4.0RC5+39438.
Except for something strange. As said before the idea was to import+create
location by a script. So I made a linux shell-script that does this:
echo "v.in.ogr dsn=mydata.shp location=import output='mydata'
min_area=0.0001 snap=-1" | grass -text "$GISDATEN/tmplocation/PERMANENT"
That works in principle and automatically imports the data from the
shapefile into location 'import'. Unfortunately only partially. One third of
the polygons gets imported, the rest is missing.
I also started grass with gui, selected "tmplocation" and the on the
commandline entered exactly the command used above (v.in.ogr dsn=mydata.shp
location=import output='mydata' min_area=0.0001 snap=-1). Then all the
objects get imported correctly.
What is that?
THX, stn
-------------- nächster Teil --------------
Ein Dateianhang mit HTML-Daten wurde abgetrennt...
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20100620/fb48dc97/attachment.html
