[GRASS-user] Automatic import ?
    Martin Landa
    landa.martin at gmail.com
    Sat Jun 19 14:00:02 EDT 2010
2010/6/19 stn <stneumann at web.de>:
> is there a way to get grass to import geodata without creating a location
> first? Grass will not start unless the location is already there or is
> created in the GUI.
> What I mean is:
> how can I write a script that will create a new location using projection
> and extent from an existing file with geodata and then import that file to
> that location? So that when starting grass the location and the data are
> already there.
start GRASS with some location, using
r.in.gdal location=<newlocation> ...
for raster data or
v.in.ogr location=<newlocation> ...
for vector data
you can create new location based on imported data and import data
into the new location in one command.
Martin
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa
