[GRASS-user] vector problems: Bad file descriptor: Files under Win7
Milton Cezar Ribeiro
miltinho.astronauta at gmail.com
Mon Jun 21 16:22:24 EDT 2010
Dear all,
I extracted drainage from DEM using r.stream.extract using several
thresholds.
I don't know why I can export the vectors generated using some threshols (50
and 1000),
but for others (500 and 2000) I get error messages (Bad file descriptor:
Files) when
exporting with v.out.ogr ....
To complicate a little bit more, the same file I exported without problem
(threshols=50),
I don't know why I get the same error message (Bad file descriptor: Files)
when
trying rasterized the heads using:
v.to.rast input=My_vetor_th0050 output=My_vetor_th0050_HEADS type=point
use=attr column=type_code
I am running all this under Windos 7.
Any help are welcome.
cheers
milton
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20100621/6575d1b2/attachment.html
