[GRASS-user] Mac Requirements for GRASS [SEC=UNCLASSIFIED]
Andrew MacIntyre
Andrew.MacIntyre at acma.gov.au
Wed Jun 23 00:24:55 EDT 2010
Tuesday, 22 June 2010 7:33 AM, William Kyngesburye wrote to Andrew Lewin:
> - memory size and speed - again, with the heavy use of temp files, faster
> and/or more memory may not help much. Though there are some things
> that can chew up a lot of memory. Memory is cheap. The memory speed
> between the current line of MacBooks, MacBook Pros, iMacs and Mac Pros
> are all the same, 1066MHz, so no real speed gain there. Memory maximum
> in the MacBooks and Pros is 8GB, vs 16GB in the iMacs and Mac Pros.
Memory can sometimes be very useful even for a temp-file architected
application like GRASS - a RAM disk or swap-backed file system can be very
worthwhile in some situations when memory is plentiful.
-------------------------> "These thoughts are mine alone!" <---------
Andrew MacIntyre Operations Branch
tel: +61 2 6219 5356 Communications Infrastructure Division
fax: +61 2 6253 3277 Australian Communications & Media Authority
email: andrew.macintyre at acma.gov.au http://www.acma.gov.au/
If you have received this email in error, please notify the sender immediately and erase all copies of the email and any attachments to it. The information contained in this email and any attachments may be private, confidential and legally privileged or the subject of copyright. If you are not the addressee it may be illegal to review, disclose, use, forward, or distribute this email and/or its contents.
Unless otherwise specified, the information in the email and any attachments is intended as a guide only and should not be relied upon as legal or technical advice or regarded as a substitute for legal or technical advice in individual cases. Opinions contained in this email or any of its attachments do not necessarily reflect the opinions of ACMA.
