[GRASS-user] Importing an small piece of the image using r.in.gdal
Daniel Victoria daniel.victoria at gmail.com
Mon Jun 21 21:33:04 EDT 2010
Check out the gdal_translate utility
http://www.gdal.org/gdal_translate.html
Actualli, it's not a grass tool but grass relies heavily on gdal tools
for raster import so chances are you have that program installed. Just
open a terminal and type gdal_translate. Use the options -projwin to
clip your image to the desired coordinates
Cheers
Daniel
On Mon, Jun 21, 2010 at 1:15 PM, katrin eggert
<katrineggert1980 at gmail.com> wrote:
> Greetings
> I'm working with LandCover global datasets and I need to import only an area
> of the dataset since my Region definition will only displays a small area
> (e.g. I'm working with European GLobcover and I only want Belgium and my
> Location/Mapset destination region  only displays Belgium). How can I only
> import a small region in order to avoid no-needed processing and data
> (because If I import and process European dataset it will take much more
> time than just belgium).
> Thanks
> Best regards,
> Katrin
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
