[GRASS-user] Importing an small piece of the image using
r.in.gdal
katrin eggert
katrineggert1980 at gmail.com
Tue Jun 22 04:26:46 EDT 2010
Greetings
THanks Daniel. Since I'm already using gdalwarp, can it be also used to only
reproject a small piece of the image?
Thanks
Best regards,
Katrin
2010/6/22 Daniel Victoria <daniel.victoria at gmail.com>
> Check out the gdal_translate utility
> http://www.gdal.org/gdal_translate.html
> Actualli, it's not a grass tool but grass relies heavily on gdal tools
> for raster import so chances are you have that program installed. Just
> open a terminal and type gdal_translate. Use the options -projwin to
> clip your image to the desired coordinates
> Cheers
> Daniel
> On Mon, Jun 21, 2010 at 1:15 PM, katrin eggert
> <katrineggert1980 at gmail.com> wrote:
> > Greetings
> > I'm working with LandCover global datasets and I need to import only an
> area
> > of the dataset since my Region definition will only displays a small area
> > (e.g. I'm working with European GLobcover and I only want Belgium and my
> > Location/Mapset destination region only displays Belgium). How can I
> only
> > import a small region in order to avoid no-needed processing and data
> > (because If I import and process European dataset it will take much more
> > time than just belgium).
> > Thanks
> > Best regards,
> > Katrin
> > grass-user mailing list
> > grass-user at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/grass-user
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20100622/cc374342/attachment.html
