[GRASS-user] Grass e QGIS on netbook with ubuntu 10.4 remix
MORREALE Jean Roc jr.morreale at enoreth.net
Tue Jun 22 02:43:16 EDT 2010
have a look to #2721 in qgis 's trac
Jean Roc
 Le mar 22/06/10 08:15, "Maris Nartiss" maris.gis at gmail.com a écrit:
> Hello,
> if You use GRASS from within QGIS, You should contact QGIS developers,
> as GRASS support in QGIS is developed by QGIS developers and not
> GRASS'ers.
> I have not used Ubuntu, still in KDE with KWin I can drag around
> windows by holding Alt key. Probably helps.
> Maris.
> 2010/6/21, Edmondo Elisei <edmo
> ndo.elisei at gmail.com>:
> I'm using qgis 1.4 as plugin in GRASS 6.4 on a eeepc
> 1008 netbook with
> ubuntu 10.4 REMIX.
> > The properties-layer panel aren't resizable and i'm
> not able to view the
> bottom command (as the "Ok" botton).
> > I've tried change the monitor resolution with the
> same result.
> Some suggestion?
> > thanks and regards (... I'm sorry for my
> english)
> > E.
> grass-user mailing list
> gr
> ass-user at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/grass-user
