[GRASS-user] Importing an small piece of the image using
r.in.gdal
katrin eggert
katrineggert1980 at gmail.com
Tue Jun 22 08:48:08 EDT 2010
hello daniel and Micha
Yes, you are right. It makes much more sense. Thanks
2010/6/22 Daniel Victoria <daniel.victoria at gmail.com>
> Katrin,
> I don't know if gdalwarp will clip your image, check the man page at
> http://www.gdal.org/gdalwarp.html
> I'd recomend you clip the image before reprojecting so you will be
> running gdalwarp in a smaller file
> Cheers
> Daniel
> On Tue, Jun 22, 2010 at 5:26 AM, katrin eggert
> <katrineggert1980 at gmail.com> wrote:
> > Greetings
> > THanks Daniel. Since I'm already using gdalwarp, can it be also used to
> only
> > reproject a small piece of the image?
> > Thanks
> > Best regards,
> > Katrin
> >> Check out the gdal_translate utility
> >> http://www.gdal.org/gdal_translate.html
> >> Actualli, it's not a grass tool but grass relies heavily on gdal tools
> >> for raster import so chances are you have that program installed. Just
> >> open a terminal and type gdal_translate. Use the options -projwin to
> >> clip your image to the desired coordinates
> >> Cheers
> >> Daniel
> >> On Mon, Jun 21, 2010 at 1:15 PM, katrin eggert
> >> > Greetings
> >> > I'm working with LandCover global datasets and I need to import only
> an
> >> > area
> >> > of the dataset since my Region definition will only displays a small
> >> > area
> >> > (e.g. I'm working with European GLobcover and I only want Belgium and
> my
> >> > Location/Mapset destination region only displays Belgium). How can I
> >> > only
> >> > import a small region in order to avoid no-needed processing and data
> >> > (because If I import and process European dataset it will take much
> more
> >> > time than just belgium).
> >> > Thanks
> >> > Best regards,
> >> > Katrin
> >> > _______________________________________________
> >> > grass-user mailing list
> >> > grass-user at lists.osgeo.org
> >> > http://lists.osgeo.org/mailman/listinfo/grass-user
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20100622/2b50645b/attachment-0001.html
