[GRASS-user] Re: v.rast.stats
Sandile Gumede akasandile at gmail.com
Tue Jun 22 08:57:00 EDT 2010
It's in mm/hr.
Are these values normal, to me it seems like big values because they are
ranging from 2000-4500, see below I just copied a few:
120795|4076||1|4076|4076|0|4076|0|0|0|4076
120796|4080||1|4080|4080|0|4080|0|0|0|4080
120797|4084||1|4084|4084|0|4084|0|0|0|4084
120798|4088||1|4088|4088|0|4088|0|0|0|4088
120799|4092||1|4092|4092|0|4092|0|0|0|4092
120800|4096||1|4096|4096|0|4096|0|0|0|4096
120801|4100||1|4100|4100|0|4100|0|0|0|4100
120802|4104||1|4104|4104|0|4104|0|0|0|4104
120803|4108||1|4108|4108|0|4108|0|0|0|4108
120804|4112||1|4112|4112|0|4112|0|0|0|4112
120805|4116||1|4116|4116|0|4116|0|0|0|4116
120806|4120||1|4120|4120|0|4120|0|0|0|4120
120807|4124||1|4124|4124|0|4124|0|0|0|4124
120808|4128||1|4128|4128|0|4128|0|0|0|4128
120809|4144||1|4144|4144|0|4144|0|0|0|4144
120810|4148||1|4148|4148|0|4148|0|0|0|4148
120811|4152||1|4152|4152|0|4152|0|0|0|4152
120812|4156||1|4156|4156|0|4156|0|0|0|4156
2010/6/22 Micha Silver <micha at arava.co.il>
>  On 22/06/2010 13:08, Sandile Gumede wrote:
> Thanks, I finally got the results.
> That's good to hear.
> Now the question I would like to ask is that, from these columns I got the
> values but which unit are these values are measured? Is it (mm) or ?
> Well, that depends on the units of the raster. If the raster values are mm.
> then each column represents mm per *raster cell*.  So if you have a rainfall
> raster with values in mm., and resolution of 10 meters, then the numbers in
> the columns are mm/100sq.m.
> Micha
> On Sat, Jun 19, 2010 at 9:57 PM, Micha Silver <micha at arava.co.il> wrote:
>>  Hello Sandile:
>> I tried to duplicate your steps and it seems to work for me.
>> Here's what I did:
>> wget ftp://trmmopen.gsfc.nasa.gov/pub/gis/3B42RT.2010032900.1day.tif
>> wget ftp://trmmopen.gsfc.nasa.gov/pub/gis/3B42RT.2010032900.1day.tfw
>>  gdalinfo 3B42RT.2010032900.1day.tif
>> Driver: GTiff/GeoTIFF
>> Files: 3B42RT.2010032900.1day.tif
>> Size is 1440, 480
>> Coordinate System is `'
>> Origin = (-180.000000000000000,60.000000000000000)
>> Pixel Size = (0.250000000000000,-0.250000000000000)
>> ---- Note: no projection info above ----
>> ---- Now I use the -projwin option of gdal_translate to select a small
>> window
>> gdal_translate -a_srs EPSG:4326 -projwin 34.0 33.0 36.0 29.0
>> 3B42RT.2010032900.1day.tif rainfall_il.tif
>> ---- GEOGCS entry now shows 4326 ----
>> g.mapset map=ASTER_DEM loc=WGS84
>> ----- A location setup as EPSG:4326----
>> r.in.gdal israel.tif out=rainfall_il
>> r.univar rainfall_il
>>  100%
>> total null and non-null cells: 77760000
>> total null cells: 0
>> Of the non-null cells:
>>  n: 77760000
>> minimum: 0
>> maximum: 34
>> range: 34
>> mean: 0.364583
>> mean of absolute values: 0.364583
>> standard deviation: 3.45241
>> variance: 11.9192
>> variation coefficient: 946.948 %
>> sum: 28350000
>> ----- Now using an existing catchment vector map ----
>> v.rast.stats vect=arava_wsheds rast=rainfall_il colpre=precip
>> v.info -c arava_wsheds
>> Displaying column types/names for database connection of layer 1:
>> INTEGER|cat
>> CHARACTER|label
>> DOUBLE PRECISION|area_km
>> INTEGER|precip_n
>> DOUBLE PRECISION|precip_min
>> DOUBLE PRECISION|precip_max
>> DOUBLE PRECISION|precip_range
>> DOUBLE PRECISION|precip_mean
>> DOUBLE PRECISION|precip_stddev
>> DOUBLE PRECISION|precip_variance
>> DOUBLE PRECISION|precip_cf_var
>> DOUBLE PRECISION|precip_sum
>> ---- and some values ----
>> v.db.select arava_wsheds
>> cat|label|area_km|precip_n|precip_min|precip_max|precip_range|precip_mean|precip_stddev|precip_variance|precip_cf_var|precip_sum
>> 21|Jordan|1055.231692|2|0|0|0|0|0|0||0
>> 19|Hidan|987.811979|2|0|0|0|0|0|0||0
>> 28|Og|124.122969|||||||||
>> 36|Zarqa|273.606213|||||||||
>> 24|Kidron|122.460114|||||||||
>> 9|Darga|289.012122|||||||||
>> 6|Arugot|236.365116|1|0|0|0|0|0|0||0
>> 26|Mujib|1277.546513|2|0|0|0|0|0|0||0
>> ---- (Many catchments have 0 or no value because of the small region I
>> chose. The global data is 1/4 degree resolution and my region is only 2 deg
>> E-W.)----
>> HTH...
>> Micha
>> On 06/17/2010 12:50 PM, Sandile Gumede wrote:
>> Hi
>> It is still giving me -NULL value error.
>> Do you think maybe its the way I downloaded my rainfall data? This is the
>> site where I downloaded my data sets*
>> ftp://trmmopen.gsfc.nasa.gov/pub/gis/ *and this data covers the whole
>> world, the only thing I did was to clip a specific region (using
>> coordinates) that is in South Africa to do my analysis. I used a bash script
>> to download and project the data, see below:
>> #!/bin/bash
>> gdal_translate -of GTiff -co "PROFILE=GeoTIFF" -co "INTERLEAVE=PIXEL" -co
>> "COMPRESS=LZW" -co "TILED=YES" -a_srs EPSG:4326 -a_ullr 18.2987501
>> -33.6795831 19.1712501 -34.3487498 3B42RT.2010032900.1day.tif
>> TRMMLast1day.tif
>> On Thu, Jun 17, 2010 at 8:41 AM, Sandile Gumede <akasandile at gmail.com>wrote:
>>> Hi
>>> #!/bin/bash
>>> TRMMLast1day.tif
>>>  2010/6/15 Micha Silver <micha at arava.co.il>
>>>>  On 15/06/2010 14:35, Sandile Gumede wrote:
>>>> Hi
>>>> If I run g.region rast=rainfall -p, I get:
>>>>   OK, what you've done here is change the current region to match the
>>>> raster "rainfall".
>>>> Can you now try:
>>>> v.rast.stats -c vect=catchments rast=rainfall pref=precip
>>>> projection: 3 (Latitude-Longitude)
>>>> zone:       0
>>>> datum:      wgs84
>>>> ellipsoid:  wgs84
>>>> north:      33:40:46.49916S
>>>> south:      34:20:55.49928S
>>>> west:       18:17:55.50036E
>>>> east:       19:10:16.50036E
>>>> nsres:      0:00:05.01875
>>>> ewres:      0:00:02.18125
>>>> rows:       480
>>>> cols:       1440
>>>> cells:      691200
>>>> and If I run r.univar rainfall, I get the following output:
>>>>  100%
>>>> total null and non-null cells: 691200
>>>> total null cells: 0
>>>> n: 691200
>>>> minimum: 0
>>>> maximum: 3094
>>>> range: 3094
>>>> mean: 22.0228
>>>> mean of absolute values: 22.0228
>>>> standard deviation: 76.1639
>>>> variance: 5800.94
>>>> variation coefficient: 345.841 %
>>>> sum: 15222164
>>>> On Tue, Jun 15, 2010 at 12:22 PM, Hamish <hamish_b at yahoo.com> wrote:
>>>>> Micha wrote:
>>>>> > The only unusual thing I notice above is that the resolution settings
>>>>> > for the raster are different N-S and E-W. This came from the original
>>>>> > tiff (see below) which also has rectangular pixels,
>>>>>  that is perfectly normal for a lat/lon map away from the equator.
>>>>> longitude scales a cos(lat).
>>>>> > (the v.rast.stats module creates a temp raster at the *current
>>>>> region's
>>>>> > resolution* settings, which might be different from this rainfall
>>>>> > raster's rectangular resolution...)
>>>>>  the results of:
>>>>> g.region -p rast=mapname
>>>>> r.univar mapname
>>>>> could help.
>>>>> Hamish
>>>> Kind Regards
>>>> TS Gumede
>>>> CSIR, Meraka Institute
>>>> 072 258 1650
>>>>  This mail was received via Mail-SeCure System.
>>>> Micha Silverhttp://www.surfaces.co.il/
>>>> Arava Development Co.  +972-52-3665918
>>> Kind Regards
>>> TS Gumede
>>> 072 258 1650
>> Kind Regards
>> TS Gumede
>> 072 258 1650
>> Micha Silver
>> Arava Development Co. +972-52-3665918http://surfaces.co.il
> Kind Regards
> TS Gumede
> 072 258 1650
Kind Regards
TS Gumede
072 258 1650
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20100622/3d312397/attachment.html
