[GRASS-user] Re: v.rast.stats
Micha Silver micha at arava.co.il
Tue Jun 22 10:26:48 EDT 2010
The raster resolution for the rainfall data was 0.25 degrees, or about
27 km. per pixel. So each pixel covers about 750 sq.km. The column with
the precip_sum will be mm/raster cell, or mm over an area of 750,000,000
sq.m.
Does that make more sense?
On 06/22/2010 03:57 PM, Sandile Gumede wrote:
> It's in mm/hr.
> Are these values normal, to me it seems like big values because they
> are ranging from 2000-4500, see below I just copied a few:
> 120795|4076||1|4076|4076|0|4076|0|0|0|4076
> 120796|4080||1|4080|4080|0|4080|0|0|0|4080
> 120797|4084||1|4084|4084|0|4084|0|0|0|4084
> 120798|4088||1|4088|4088|0|4088|0|0|0|4088
> 120799|4092||1|4092|4092|0|4092|0|0|0|4092
> 120800|4096||1|4096|4096|0|4096|0|0|0|4096
> 120801|4100||1|4100|4100|0|4100|0|0|0|4100
> 120802|4104||1|4104|4104|0|4104|0|0|0|4104
> 120803|4108||1|4108|4108|0|4108|0|0|0|4108
> 120804|4112||1|4112|4112|0|4112|0|0|0|4112
> 120805|4116||1|4116|4116|0|4116|0|0|0|4116
> 120806|4120||1|4120|4120|0|4120|0|0|0|4120
> 120807|4124||1|4124|4124|0|4124|0|0|0|4124
> 120808|4128||1|4128|4128|0|4128|0|0|0|4128
> 120809|4144||1|4144|4144|0|4144|0|0|0|4144
> 120810|4148||1|4148|4148|0|4148|0|0|0|4148
> 120811|4152||1|4152|4152|0|4152|0|0|0|4152
> 120812|4156||1|4156|4156|0|4156|0|0|0|4156
> 2010/6/22 Micha Silver <micha at arava.co.il <mailto:micha at arava.co.il>>
>     On 22/06/2010 13:08, Sandile Gumede wrote:
>>     Thanks, I finally got the results.
>     That's good to hear.
>>     Now the question I would like to ask is that, from these columns
>>     I got the values but which unit are these values are measured? Is
>>     it (mm) or ?
>     Well, that depends on the units of the raster. If the raster
>     values are mm. then each column represents mm per *raster cell*.
>     So if you have a rainfall raster with values in mm., and
>     resolution of 10 meters, then the numbers in the columns are
>     mm/100sq.m.
>     Micha
>>     On Sat, Jun 19, 2010 at 9:57 PM, Micha Silver <micha at arava.co.il
>>     <mailto:micha at arava.co.il>> wrote:
>>         Hello Sandile:
>>         I tried to duplicate your steps and it seems to work for me.
>>         Here's what I did:
>>         wget
>>         ftp://trmmopen.gsfc.nasa.gov/pub/gis/3B42RT.2010032900.1day.tif
>>         wget
>>         ftp://trmmopen.gsfc.nasa.gov/pub/gis/3B42RT.2010032900.1day.tfw
>>         gdalinfo 3B42RT.2010032900.1day.tif
>>         Driver: GTiff/GeoTIFF
>>         Files: 3B42RT.2010032900.1day.tif
>>         Size is 1440, 480
>>         Coordinate System is `'
>>         Origin = (-180.000000000000000,60.000000000000000)
>>         Pixel Size = (0.250000000000000,-0.250000000000000)
>>         ---- Note: no projection info above ----
>>         ---- Now I use the -projwin option of gdal_translate to
>>         select a small window
>>         gdal_translate -a_srs EPSG:4326 -projwin 34.0 33.0 36.0 29.0
>>         3B42RT.2010032900.1day.tif rainfall_il.tif
>>         ---- GEOGCS entry now shows 4326 ----
>>         g.mapset map=ASTER_DEM loc=WGS84
>>         ----- A location setup as EPSG:4326----
>>         r.in.gdal israel.tif out=rainfall_il
>>         r.univar rainfall_il
>>          100%
>>         total null and non-null cells: 77760000
>>         total null cells: 0
>>         Of the non-null cells:
>>         n: 77760000
>>         minimum: 0
>>         maximum: 34
>>         range: 34
>>         mean: 0.364583
>>         mean of absolute values: 0.364583
>>         standard deviation: 3.45241
>>         variance: 11.9192
>>         variation coefficient: 946.948 %
>>         sum: 28350000
>>         ----- Now using an existing catchment vector map ----
>>         v.rast.stats vect=arava_wsheds rast=rainfall_il colpre=precip
>>         v.info <http://v.info> -c arava_wsheds
>>         Displaying column types/names for database connection of layer 1:
>>         INTEGER|cat
>>         CHARACTER|label
>>         DOUBLE PRECISION|area_km
>>         INTEGER|precip_n
>>         DOUBLE PRECISION|precip_min
>>         DOUBLE PRECISION|precip_max
>>         DOUBLE PRECISION|precip_range
>>         DOUBLE PRECISION|precip_mean
>>         DOUBLE PRECISION|precip_stddev
>>         DOUBLE PRECISION|precip_variance
>>         DOUBLE PRECISION|precip_cf_var
>>         DOUBLE PRECISION|precip_sum
>>         ---- and some values ----
>>         v.db.select arava_wsheds
>>         cat|label|area_km|precip_n|precip_min|precip_max|precip_range|precip_mean|precip_stddev|precip_variance|precip_cf_var|precip_sum
>>         21|Jordan|1055.231692|2|0|0|0|0|0|0||0
>>         19|Hidan|987.811979|2|0|0|0|0|0|0||0
>>         28|Og|124.122969|||||||||
>>         36|Zarqa|273.606213|||||||||
>>         24|Kidron|122.460114|||||||||
>>         9|Darga|289.012122|||||||||
>>         6|Arugot|236.365116|1|0|0|0|0|0|0||0
>>         26|Mujib|1277.546513|2|0|0|0|0|0|0||0
>>         ---- (Many catchments have 0 or no value because of the small
>>         region I chose. The global data is 1/4 degree resolution and
>>         my region is only 2 deg E-W.)----
>>         HTH...
>>         Micha
>>         On 06/17/2010 12:50 PM, Sandile Gumede wrote:
>>>         Hi
>>>         It is still giving me -NULL value error.
>>>         Do you think maybe its the way I downloaded my rainfall
>>>         data? This is the site where I downloaded my data sets_
>>>         ftp://trmmopen.gsfc.nasa.gov/pub/gis/ _and this data covers
>>>         the whole world, the only thing I did was to clip a specific
>>>         region (using coordinates) that is in South Africa to do my
>>>         analysis. I used a bash script to download and project the
>>>         data, see below:
>>>         #!/bin/bash
>>>         wget
>>>         wget
>>>         gdal_translate -of GTiff -co "PROFILE=GeoTIFF" -co
>>>         "INTERLEAVE=PIXEL" -co "COMPRESS=LZW" -co "TILED=YES" -a_srs
>>>         EPSG:4326 -a_ullr 18.2987501 -33.6795831 19.1712501
>>>         -34.3487498 3B42RT.2010032900.1day.tif TRMMLast1day.tif
>>>         On Thu, Jun 17, 2010 at 8:41 AM, Sandile Gumede
>>>         <akasandile at gmail.com <mailto:akasandile at gmail.com>> wrote:
>>>             Hi
>>>             covers the whole world, the only thing I did was to clip
>>>             a specific region (using coordinates) that is in South
>>>             Africa to do my analysis. I used a bash script to
>>>             download and project the data, see below:
>>>             #!/bin/bash
>>>             wget
>>>             wget
>>>             -a_srs EPSG:4326 -a_ullr 18.2987501 -33.6795831
>>>             19.1712501 -34.3487498 3B42RT.2010032900.1day.tif
>>>             TRMMLast1day.tif
>>>             2010/6/15 Micha Silver <micha at arava.co.il
>>>                 On 15/06/2010 14:35, Sandile Gumede wrote:
>>>>                 Hi
>>>>                 If I run g.region rast=rainfall -p, I get:
>>>                 OK, what you've done here is change the current
>>>                 region to match the raster "rainfall".
>>>                 Can you now try:
>>>                 v.rast.stats -c vect=catchments rast=rainfall
>>>                 pref=precip
>>>>                 projection: 3 (Latitude-Longitude)
>>>>                 zone:       0
>>>>                 datum:      wgs84
>>>>                 ellipsoid:  wgs84
>>>>                 north:      33:40:46.49916S
>>>>                 south:      34:20:55.49928S
>>>>                 west:       18:17:55.50036E
>>>>                 east:       19:10:16.50036E
>>>>                 nsres:      0:00:05.01875
>>>>                 ewres:      0:00:02.18125
>>>>                 rows:       480
>>>>                 cols:       1440
>>>>                 cells:      691200
>>>>                 and If I run r.univar rainfall, I get the following
>>>>                 output:
>>>>                  100%
>>>>                 total null and non-null cells: 691200
>>>>                 total null cells: 0
>>>>                 n: 691200
>>>>                 minimum: 0
>>>>                 maximum: 3094
>>>>                 range: 3094
>>>>                 mean: 22.0228
>>>>                 mean of absolute values: 22.0228
>>>>                 standard deviation: 76.1639
>>>>                 variance: 5800.94
>>>>                 variation coefficient: 345.841 %
>>>>                 sum: 15222164
>>>>                 On Tue, Jun 15, 2010 at 12:22 PM, Hamish
>>>>                 <hamish_b at yahoo.com <mailto:hamish_b at yahoo.com>> wrote:
>>>>                     Micha wrote:
>>>>                     > The only unusual thing I notice above is that
>>>>                     the resolution settings
>>>>                     > for the raster are different N-S and E-W.
>>>>                     This came from the original
>>>>                     > tiff (see below) which also has rectangular
>>>>                     pixels,
>>>>                     that is perfectly normal for a lat/lon map away
>>>>                     from the equator.
>>>>                     longitude scales a cos(lat).
>>>>                     > (the v.rast.stats module creates a temp
>>>>                     raster at the *current region's
>>>>                     > resolution* settings, which might be
>>>>                     different from this rainfall
>>>>                     > raster's rectangular resolution...)
>>>>                     the results of:
>>>>                     g.region -p rast=mapname
>>>>                     r.univar mapname
>>>>                     could help.
>>>>                     Hamish
>>>>                 Kind Regards
>>>>                 TS Gumede
>>>>                 CSIR, Meraka Institute
>>>>                 072 258 1650
>>>>                 This mail was received via Mail-SeCure System.
>>>                 Micha Silver
>>>                 http://www.surfaces.co.il/
>>>                 Arava Development Co.  +972-52-3665918
>>>             Kind Regards
>>>             TS Gumede
>>>             072 258 1650
>>>         Kind Regards
>>>         TS Gumede
>>>         072 258 1650
>>         Micha Silver
>>         http://surfaces.co.il
>>     Kind Regards
>>     TS Gumede
>>     072 258 1650
>     Micha Silver
> Kind Regards
> TS Gumede
> 072 258 1650
Micha Silver
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20100622/33ee9d1a/attachment-0001.html
