[GRASS-user] SQLite connection - error
Markus Metz
markus.metz.giswork at googlemail.com
Thu Jun 24 07:12:43 EDT 2010
On Thu, Jun 24, 2010 at 10:35 AM, Espen Isaksen <espen.isaksen at gmail.com> wrote:
> Thanks Achim and Ben for your quick answers! I never even thought
> about that(a bit embarrassing really :-) )
> I suppose that means I am back to the horribly slow import through
> v.in.ogr. Practically impossible for me to import a 100 mb shapefile.
> If anybody has suggestions for good performance, please go ahead and
> tell me.
You could try grass 7, see [1]
Really big shapefiles like GADM v1 (gadm1.shp is 913 MB) will take at
least 1 hour, though.
Alternatively, get v.in.gshhs from grass-addons [2], get the original
GSHHS data [3] and import those with v.in.gshhs
Markus M
[1] http://grass.osgeo.org/wiki/GRASS_7_ideas_collection#Radim.27s_TODO_list
[2] http://grass.osgeo.org/wiki/GRASS_AddOns#v.in.gshhs
[3] ftp://ftp.soest.hawaii.edu/pwessel/gshhs/gshhs_2.0.tbz
> 2010/6/24 Achim Kisseler <achim.kisseler at jupiter.uni-freiburg.de>:
>> This is because SQLite is not SpatiaLite (SQLite with spatial extension).
>> GRASS does not support SpatiaLite as far as I know.
>> If you just want to use the Data from Spatiallite, you can export the tables
>> as shape-files or csv and import these to GRASS.
>> Hope it helps a bit,
>> Achim
>> Espen Isaksen schrieb:
>>> Hi!
>>> I have tried to read the documentation and the mailing list for how to
>>> connect to a SQLite database. So far I have done this:
>>> 1. db.connect driver=sqlite database='/home/espen/db.sqlite'
>>> 2. Created a new vector map called test
>>> 3. v.db.connect map=test table=GSHHS_f_L2 -o key=PK_UID
>>> However I get this warning:
>>> WARNING: SQLite driver: unable to parse decltype: POLYGON
>>> WARNING: SQLite driver: column 'Geometry', SQLite type 2 is not supported
>>> The table <GSHHS_f_L2> is now part of vector map <test> and may be deleted
>>> or overwritten by GRASS modules
>>> And running v.info map=test show that the layer does not have any objects
>>> | Layer: test
>>> | Mapset: PERMANENT
>>> | Location: newLocation
>>> | Database: /home/espen/Dokumenter/grassdata
>>> | Title:
>>> | Map scale: 1:1
>>> | Map format: native
>>> | Name of creator: espen
>>> | Organization:
>>> | Source date: Wed Jun 23 08:55:30 2010
>>> | Type of Map: vector (level: 2)
>>> | Number of points: 0 Number of areas: 0
>>> | Number of lines: 0 Number of islands: 0
>>> | Number of boundaries: 0 Number of faces: 0
>>> | Number of centroids: 0 Number of kernels: 0
>>> | Map is 3D: No
>>> | Number of dblinks: 1
>>> | Projection: Lat/Lon
>>> | N: 0 S: 0
>>> | E: 0 W: 0
>>> | Digitization threshold: 0
>>> | Comments:
>>> Could anybody explain to me what the warning means, and why I cannot
>>> access the features? The only thing i can guess is that I can only use
>>> version 1 of SQLite? However, I am not familiar with the different
>>> versions of SQLite.
>>> Kind regards,
>>> Espen Isaksen
>>> grass-user mailing list
>>> grass-user at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/grass-user
